Could you help me to control a DC motor with the parallel port and windows 2000?
I have labview 5.1 and i want to control my application throught the internet
(2,605 Views)
I would recommend upgrading to LabVIEW 7.0 for a couple of reasons. First, LabVIEW 6.1 introduced remote front panels which allows you to control a VI through a web browser. Setting up remote front panels is very simple and that alone is worth the upgrade. As far a using the parallel port you can use VISA to send/receive commands via the parellel port if you are using a motor controller with a parellel interface. If you are talking about using the port on a bit level to control the motor, LabVIEW 7.0 ships which an example of how to do basic digital input output with the parallel port.
JR A.
Application Engineer
(2,605 Views)
