noise and dithering
Hi...
I want to reduce the noise and I read about dithering,
I´m using the daq 6024e, and I need to know if I only need to enable dithering with MIO config, or if I must enable dithering with MIO and add gaussian noise to the signal...
thanks
(3,747 Views)
Your manual should tell you this for certain, but I believe the definition of dithering is the addition of noise for the purpose of improving the measurement.
In other words, do NOT add your own noise to the signal.
Steve Bird
Culverson.com
LinkedIn
(3,747 Views)
Why not look into signal conditioning? SCXI
http://sine.ni.com/apps/we/nioc.vp?cid=1604〈=US
(3,747 Views)
Addition of noise for dithering reduces quantization noise. The easiest
example are screen fonts which look 'blocky' unless grey scale pixels
are added. Where else would you add noise?
(3,747 Views)
When you turn on dithering on any NI boards that support it, the noise is added for you, if I remember correctly. You don't need to hook up a noise generator externally.
Steve Bird
Culverson.com
LinkedIn
(3,747 Views)
