Counter with NI-9375
I am using a NI-9375 connected to a CDAQ 9184 to collect the output from an inductive proximity sensor (DI0 input on the NI-9375).  The proximity sensor is used to count the rotations of a wheel attached to a motor.  The edge of the wheel has a screw that trips the proximity sensor each time it comes around.  The desired result is a counter that counts the rotations of the motor.  The NI-9375 does not have a built-in counter.  How do I use LabView to count the output of the proximity sensor?
(3,825 Views)
Accepted by topic author carlisle1
Usually one uses the counter of the cDAQ-chassis for that.
Regards, Jens
Kudos are welcome...
(3,817 Views)
Thank you!
(3,801 Views)
could you please go in more depth in explaining how to use the cDAQ counter?
how to bring it in use in Labview VI or programming?
I was also recommended to use shift registers for the same. please share a link or video on both: Shift registers and cDAQ counters.
(3,028 Views)
Hi Redox,
instead of videos you could read the KnowledgeBase articles by NI like this
(3,018 Views)
