Voltage Divider for Inductive Proximity Sensor
Hi LabView Board,
Please refer to the image shared on : https://forums.ni.com/t5/Multifunction-DAQ/Inductive-proximity-sensor-reading/m-p/2616659#M79464
I am reposting as a fresh question.
I was considering a similar implementation for my circuit using the proximity sensor. However, given with my basics of the voltage divider and considering the following:
Vi as the input voltage
R1, R2 as divider resistances
V1, V2 respective voltage drops
then, V1= Vi * (R1/(R1+R2)) and V2 = Vi * (R2/(R1+R2)).
the circuit configuration marked as the solution has R1 & R2 indicated as 1000 Ohm and 1500 Ohm. The output across R2 is given input to 0-10V range DAQ.
Now calculating V2 as per given values and above formula:
V2 = Vi * (R2/(R1+R2)) = 24 * (1500/(1000+1500)) = 24 * 1500 / 2500 = 14.4 V
definitely 14.4 V shouldn't be the input to the DAQ!
Higher resistance has a higher voltage drop across it and vice versa.
then why DAQ is connected to higher resistance R2?
Kindly clarify.
(4,177 Views)
hi,
I was considering similar implementation for my circuit using proximity sensor. However given with my basics of voltage divider and considering the following:
Vi as input voltage
the circuit configuration marked as solution has R1 & R2 indicated as 1000 Ohm and 1500 Ohm. The output across R2 is given input to 0-10V range DAQ.
definitely 14.4 V shouldn't be the input to the DAQ! Kindly clarify
(4,179 Views)
Accepted by topic author Redox_07
Hi Redox,
when you swap the resistance values to R1=1500 Ohm and R2=1000 Ohm then everything looks nice.
Probably a simple glitch by Lynn…
(4,168 Views)
I had a headache wondering why why why? thanks to you.
(4,161 Views)
Hi Redox,
as an engineer (to be) you should be able to apply simple voltage divider (Kirchhoff's rules) on your own without getting headache…
(4,158 Views)
