Counting with a button
Try adding an indicator to the itteration counter (the "i" in the lower left-hand corner of the for-loop).  It might help if you change the default value to something other than zero, as the first itteration will have a value of zero.  If it doesn't change at all, your program is never making it to the for loop. If it counts very rapidly, then it is something else.
Cheers.
Message 21 of 21
(583 Views)
