Crane Electronics UTA Rotary Transducer - pco422.doc (0/1)
"I'm trying to get a Crane Electronics UTA Rotary Transducer to talk
to MAX with no luck. This is a steel drive shaft located in low
friction ball bearings. The shaft incorporates a Wheatstone Bridge
strain gauge circuit and precision slip ring assembly rigidly attached
to the input end of the shaft. You can view it at
http://crane-electronics.com, click on Products then Transducers. I'm
using a PCI-1200 DAQ card with a CB-50LP I/O connector block. The
attachment shows the schematic, but I don't know which to connect to
for the power and data. The manual says that I should see +3.250 volts
when turning clockwise, -3.250 volts turning counterclockwise, and
zero torque should be 0v. I think the unit is a floating grou
nd but I
could be wrong. This is my first project as I am learning LabView and
DAQ. Crane Electronics doesn't want to help me other than give me the
schmatic. Can someone give me a hand with this?"
(2,431 Views)
Hello;
This is a issue specificaly regarding Crane Electronics. They must give you more than just schematics. Contact them again and ask for more detailed information on how to connect power and data lines.
Filipe
(2,431 Views)
