Creat new files at the beginning of every hour
I am trying to write a VI to store data in text file. To avoid a too large file, I want to store the data in different files. I want these files to be created at the beginning of every hour. How could I achieve this?
Thanks in advance!
Message 1 of 14
(4,821 Views)
Hey,
Maybe you could integrate this in your code. It will increment the number in the filename every half second.
Rgds - Rkll
Message 2 of 14
(4,803 Views)
Hey,
Rgds - Rkll
Message 3 of 14
(4,803 Views)
Accepted by masterwho
Many people like to have a timestamp in their file name.  Makes it unique and gives information on the time the file was created.  Here is some code that will create a new filename with timestamp every hour on the hour.  It checks every second to see if the minutes part of the time string is "00".  If so, then it creates a filename.  The date string keeps it unique from day to day.
20513i32A3BF8B9A8B7A63
Ooops. Just noticed a flaw.  The code will create a new filename every second as long as the minutes are 00.  Changing the delay value to one minute (60000) should fix the problem.
- tbob
Inventor of the WORM Global
Message 4 of 14
(4,760 Views)
Thank you for your help. It's very helpful!
Message 5 of 14
(4,723 Views)
Thank you very much for your reply. I tried to use time stamp to control the creation of the files. However, it seems that the wait function isn't stable enough, it didn't sample as expected. For example, I set the wait function to wait for 10ms, but it delays for about 12ms. It's really weird! Do you know how to fix it?
Thanks a lot!
Message 6 of 14
(4,719 Views)
Can I have one more question?
I tried to use the way you told me to control the creation of the files. However, it seems that the wait function isn't stable enough, it didn't sample as expected. For example, I set the wait function to wait for 10ms and jump out of the ture or false loop to check whether the minute is 00, but it delays for about 12ms. So if I use a for loop with 360,000 iterations, and set a wait for 10ms in each loop, it always misses the minute of 00. It's really weird!
Thank you very much!
Message 7 of 14
(4,714 Views)
I saw a video a while ago. It's about timing and that sort. I'm at work now and don't have to possibility to view the video, but I think it should be relevant.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 8 of 14
(4,707 Views)
I like the video very much. It's really a nice one and very helpful.
Message 9 of 14
(4,693 Views)
Glad to help:) That guy have many nice videos that also might be useful some day.
Even
Topro AS
Norway
Message 10 of 14
(4,685 Views)
