Create Cursor From File.vi
Does anyone have an example of how to use this function?
(2,045 Views)
Hi Max,
The help for this function is quite clear: provide a filepath and the hotspot position (MacOS requires a 3rd parameter).
What is your real question?
(Btw. the SetBusy and the DestroyCursor functions accept a CursorID input…)
(2,033 Views)
I was not able to use this function and therefore I am asking for an example using .ani or .cur files
(1,991 Views)
Open LabVIEW.  Click "Help" on the menu bar, choose "Find Examples", and search for "Cursor".  Study the examples.
(1,969 Views)
There is no example that uses the specific function.
(1,955 Views)
Accepted by maxnoder1995
Could you please be more specific what are you asking about?
All you should do when you replace in example file Set Cursor.vi with Create Cursor From File.vi is
- any .png file converted to .cur format using for example https://convertio.co/ online converter
-- used for this example png was 128x128 pixel size
(1,931 Views)
