Create Desktop PC Boot Disk is Disabled
In MAX>>Tools>>RT Disk utilities>> Create  Desktop PC Boot Disk is disabled. How to enable it? I'm using LabVIEW 7.1 and LabVIEW Real time module 7.1. What other softwares do I need to convert my Desktop PC as a LabVIEW 7.1 Real time target?
(4,347 Views)
There are quite a few links for this on the NI Website.
Converting a Desktop PC to LabVIEW Real-Time Target
http://zone.ni.com/wv/app/doc/p/id/wv-309
Requirements for a Desktop PC as a Real-Time Target
http://digital.ni.com/public.nsf/allkb/440BAF128AA75F95862572580081EB3D
Here's the search I did
http://search.ni.com/nisearch/main/p?q=desktop+realtime&x=0&y=0
I've never tried this myself.  But I've been interested in it for some time.  Good luck with your project.
Patrick Allen: FunctionalityUnlimited.ca
(4,336 Views)
Hi Giridhar,
Thanks for the post!
Did you work out the issue?
and does your machine meet the Requirements for a Desktop PC as a Real-Time Target?
also have you tried running the RT Compatible Utility?
Kind Regards,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,322 Views)
Thanks for your reply. I have already read these links but none of them talk about how to enable the RT Disk Utilities >> Create Desktop PC Boot Disk. I have installed LabVIEW 7.1 and LabVIEW Real time 7.1 module.
(4,308 Views)
Hi Giridhar,
Have you run the device drivers setup after installing the LabVIEW Real-time module? Make sure all the support options for LabVIEW Real-Time 7.1 is selected during the installation.
Hope this helps,
Cheers!
Sanka Smiley Happy
(4,298 Views)
