make waveform graph signals look steady
Hi everybody!
 I need some help, i am continuously acquiring 4 diferent analog  signals using a usb 6009.At the same time i´m using the pfio terminal for doing some  triggerring.
Since i must use the cursors for calculating frequency, amplitude and period. It is necessary that all these 4 signals appear steady (not moving) so i can use the cursors.
By now i´ve been trying to accomplish this using the Trigger express Vi, but just one of the signals appear steady and i need the four signals appear steady . Besides, i would like to have the ability to show the signals moving( as they are now  presented) and when i decide to make the measurements with the cursors the signals just appear steady( not moving). Any ideas about how to do this?
(2,976 Views)
Riot,
first of all the bad news: i have serious doubts that you can solve your request at all using the 6009.
Here is why:
- If your 4 signals don't have the exact same frequency, it will never work since you can trigger only on a single signal.
- There are three ways to stabilize the signal during display:
a) The acquisitionrate is a multiple of the signal's frequency which is of type integer (so e.g. 20). If the multilple is floating point, the signal will move.
b) You acquire a finite amount of samples and trigger on the same position of the signal (e.g. zero-crossing).
c) you acquire a finit amount of samples and no more. Then you display this data for analysis. If analysis is finished, you'd acquire the next set of data.
- a) is very unlikely to happen (i'd asume that you will get the jackpot in the lottery easier than this).
- b) is impossible with the 6009, you'd need a scope device for this.
So if any solution works, c) would be the one.
If you want to have a "moving signal", you could switch between continuous acquisition (moving) and finite (static).
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,957 Views)
