Installer (LV 8.5): Can not disable "Run executable after installation" / Error 193
I'm working with an LabVIEW-Project in 8.5, which was originaly created with Version 8.2.1.
The application runs as before under 8.2.1, but I've problem with the installer on 8.5:
Running the created setup shows at the end "Error 193: Failed to perform action xyz.dll"  (xyz is the name of an used dll).
It seems that the installation runned, the files are installed - but why this error?
To localize the reason for this error (wich not appeard with the same setup created on 8.2.1), I found that I can not deactivate the Advanced option "Run executable after installation": I can uncheck this option and confirm with [ok], but after opening the installer properties the checkbox is active again!
I do not know, if there is an cohesion between this strange behavior / error.
Any idea?
(4,137 Views)
Hi Zav,
To solve this issue you must open your .lvproj file into a word editing document and delete the lines corresponding to this two lines if you open the attached project in a Word document:
{FE639E01-8D0D-4EB6-83A2-C0AAD5380494}
{55AA37A1-CF95-458A-A15B-764B3D440361}
I tried with a project on my computer and it works.
Have a nice day.
Regards.
Matthieu
NI Switzerland
(4,109 Views)
Hey there
I´ve got the same problem with a windows icon (*.ico).
Mathieu …  wrote:
I must change lines corresponding to this two lines
Is this correct? In case is true, which lines in the .lvproj file I have to change?
(3,866 Views)
