Create Height field from 3D point cloud
There is a VI called: Create Height Field.vi to craete surface to 3D picture control.
"Converts a 2D array of values to a 3D height field and applies the height field to a 3D object that appears in a 3D scene."
This should be perfect for me ( this function interpolates the whole surface) but, I have 3D  [x,y,z] point cloud, where the coordinates are not equally spaced. As I understad this VI can display point cloud with equidistant coordinates. How can I use this tool to display my data?
I have tried the Create Mesh.vi to display my point cloud, but I really need the interpolated surface also. Could you give me some guide points where and how to do now?
Thanks in advance,
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,585 Views)
Accepted by topic author D60
Hi D60!
Sorry for the late reply.
Is your problem still unsolved?
If yes, I searched for some examples that use the Create Height Field VI.
I only found one example code on Community: https://decibel.ni.com/content/docs/DOC-4765
If your data points are not sampled on the same rate, you could use interpolation, to reach the same length.
I guess the easiest way is to use the Mathscript node for this, like in this eaxmple: http://zone.ni.com/reference/en-XX/help/371361F-01/lvtextmath/msfunc_interpolate/
Or this VI could be used for the same purpose: http://zone.ni.com/reference/en-XX/help/371361J-01/gmath/interpolate_2d/
Please let me know, if my suggestions helped. If you have any questions, please don't hesitate to post them.
Best Regards,
CLA, CLED
(3,473 Views)
Dear Balázs,
I will check your suggestion and write a feedback soon.
Thanks for your help!
[Hungary]
(3,450 Views)
Hi D60!
Were my suggestions useful? Could you solve the issue?
Do you have any other questions, relating to this topic?
Best Regards,
CLA, CLED
(3,414 Views)
Dear Balazs Nagy,
I was out of office and I totally forgot this issue, Sorry for that and thanks for the update.
Your suggestions about 2D interpolation seem OK and very useful.
Thank you so much and have a nice day!
[Hungary]
(3,408 Views)
Hi D60!
I'm happy, that you could solve this issue using my suggestions.
Thanks for the feedback! Have a nice day too!
Bes Regards,
CLA, CLED
(3,405 Views)
