Create Installer Fail, but Application success. HELP, URGENT!
Hi all,
I met a strange problem. My labview 8.5 PDS failed to create Installer, yet the application can be built and run. When I want to  create the installer, no information in the "Additional Installer", and no *.bld files created. When I want to build it, some error information reported as below:
"CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Validate_DistParts.vi >> CDK_DistParts_GetInstalledProducts.vi >> NI_MDF.lvlib:MDFProdInfoList_Open.vi" .
When I tried to create a simple vi show a random number, the application can run, the installer can not be built. The error information changed: "CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Validate_DistParts.vi >> CDK_DistParts_GetInstalledProducts.vi >> NI_MDF.lvlib:MDFCommon_Open.vi".
Additional Information: Before I re-install my windows xp, the Labview Application Builder worked.
And I've tried the conversations "http://forums.ni.com/ni/board/message?board.id=170&message.id=316712&requireLogin=False" , "http://forums.ni.com/ni/board/message?board.id=250&thread.id=29940&view=by_date_ascending&page=2"  and "http://forums.ni.com/ni/board/message?board.id=170&message.id=244845&query.id=526126#M244845". But I'm not such lucky.
I've even tried to re-install LabView including deleting LabView related registry key value.
Thanks.
Black Ma
(4,681 Views)
AFAIK, LabVIEW 8.5 does not use .bld files. Did you make your project by converting an old *.bld file?
(4,667 Views)
Sorry.
I create my project from the scratch on LabView 8.5. And the installer creating fails.
Always the blank content in Additional Installer Tab page. And alway some error information reported as above.
Thanks.
Black Ma
(4,644 Views)
MaGH, I've having a very similar issue with LV2009.
The build was unseccessful.
Possible reasons
Details:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
_____________________
Of course reinstalling, mass compiling, deleting and recreating didn't help.
I've attached a sample code here:
http://forums.ni.com/t5/LabVIEW/Installer-Build-Unsuccesful/td-p/1646134
Have you been able to solve this problem?
I don't really know how I can distribute my products....
thanks
(3,619 Views)
I am having the same issue with LV 8.6 & WinXP (everything updated like .NET, etc.). Any luck finding what's going on?
(3,579 Views)
I am having also the same issue with LV 8.6 & WinXP
Friedrich Vollink
(3,517 Views)
