VI's with DAQmx run, but compiled to .net dll the functions hang
We have a library for simple IO (Read/Write Bit/Byte N Bits)
It runs fine if I use the VI's directly, however, when I compile to a .net dll something goes wrong...
In a labview aplication I am able to call the constructor, call methods (the functions are also recognized) and everything looks fine.
When I run the program, it hangs at the first custom function called. It hangs, so I dont get any error...
I have added the project, VI.llb and compiled dll
I tried to mass-compile, but it didnt help and I call a standard added function (gettype) as initialization like this link (but they apply it in C#)
Could anyone help me?
(3,043 Views)
Could anyone confirm that the dll is indeed not working?
And what could be the problem?
Tip: close/save all other LV vi's: LV could hang (kill Labview.exe in taskmanager is enough to recover)
Other .net compiled dll's work fine, so only the one with DAQmx give problems...
(3,039 Views)
Can no one help me?
(3,032 Views)
Hmm, 1 day further....
Is there by any chance a Labview designer that knows how to help me?
(3,023 Views)
Could anyone look at my problem please?
(3,012 Views)
Dear Hans,
Sorry for the delay in our response. I rebuild the .NET assembly and it was located in the \build directory at the directory where the VI selftest-manual.dll.vi was located in. This last VI did run without any problems (did run it multiple times).
- Was the assembly located in the same directory as your PC?
- does a simple assembly (so without calling a DAQ driver but only basic Labview functions) work?
Martijn S
NI Netherlands
(2,987 Views)
I did rebuild the assembly too and at my side it still hangs at the code call.
I have another .net dll with labview only modules which works fine:
- Create a directory
- WaitwithGUI
- Transpose2DArray (when I swith from bare vi to .net dll the 2 dimensions are switched...)
- Measurement to HTML file (2D array)
- Measurement to PNG (2D array)
I have a third .net dll which runs semi-stable
- 1 function goes wrong sometimes but that could be a code problem. Teststand however only gives error code -17500: exception in .net call, so I dont know what the real problem is.
I forgot to mention which version I use:
Teststand 2010 + patch f1 (developer version)
DAQmx 9.2.3
At the end it has to run on an operator machine.
Alvast bedankt voor de hulp / thanks in advance
(2,980 Views)
