PCI 7830R series DAQ card with SCB 68
Can anybody how to mapp PCI 7830R card with SCB68, which was connected in 0 connector? is thier any VI as an example for this
Message 1 of 8
(3,457 Views)
I am having PCI 7830 R card in PC... and also i am having SCB68 Connector block... there is no real world source generator or source .. i want to show the output in Labview... by connecting wires on SCB68 block in output which map with 7830R card... so is it possible?... if so, let me know which pin i want to connect in SCB68...and i cnat found example VI for mapping this DAQ card with connector block......
Message 2 of 8
(3,448 Views)
suppose i am not connecting 9v battery or any other real world sourse to the SCB card.... but i  just want to show some output in labview front panel (whether it may be acquiring data or analysing or LED  blinking) just to confirm that connector block SCB68  and PCI7830R card are mapped with each other... inorder to prove this how could i want to create a VI? in wich methode i want to create ? i am just learnning labview so if my question seems to be wrong just give me a correct answer ...
Message 3 of 8
(3,447 Views)
Hi alieas
I am sorry but I was not able to fully understand your query. Upto what I understand, you want to know how to map pins on SCB-68 connector block with DAQ card.
Following is the link where you can find the pin out details ( which pin on SCB connector links to which channel on the DAQ card ).
http://www.msm.cam.ac.uk/mechtest/docs/scb68%20manual.pdf
Ashutosh Singh
Message 4 of 8
(3,426 Views)
Oh .. its ok sir ... i can explain simple.... i have SCB68 and PCI7830R DAQ card... DAQ was installed inside PC , i connect this card with SCB68 thro SHC68-RMIO cable (0 Connector)... now i tested the AI, AO, and Digital pins of PCI7830R card (without connecting SCB 68)  through Labview code example ... and it was working..... now i want to test by connecting SCB68 with the DAQ card .... if i want to do that in FPGA(Project Explorer methode) means ...what r the steps to do that?
i will not have rights to connect any Sourse generator or signal generator in SCB 68 to show output...... instead of that i have to show output in Labview frontpanel means.... how could i want to create that type of VI?
Message 5 of 8
(3,424 Views)
Let me use this example ... ? if it wrong say me how to correct....
Suppose i connect 9 volt battery ,+ve to AI0+ (pin 68) and battery -ve to AIGND0 (pin 67) of SCB 68 , (SCB68 which connected with DAQ PCI7830R)
how should i want to create aVI in (Project Explorer Methode )correspond to the above one.... the graph should shown continious waveform.... any examples ?.... or any this type of idea regarding to prove that DAQ card and Connector block is in working condition...
Message 6 of 8
(3,417 Views)
Hello Sir.... i created a VI in Project Explorer Methode to test the working condition of DAQ card PCI 7830R which i installed in my PC , in both Sub VI and the Host VI the programme is working , now i connect the SCB 68 hardware with DAQ card thro RMIO cable , i wired the DIgital Pins of SCB68 (respectievely with DAQ card Pins) in a Bread Board an place a LED corresponding to pins to show the real world output...
  Now my prob is after i connecting the wire i run the VI, in breadboard the LED's are not getting ON same status is displayed in Labview Front panel too , when i remove the wire the LED in front panel of both sub and Host VI is getting ON..... y this prob occuring? to solve this what i have to do? i want to show realworld output (LED On in Bread board) thro SCB68... how to solve this?
Message 7 of 8
(3,395 Views)
Message 8 of 8
(3,390 Views)
