Create New Reference from Existing Reference
I have a VI where I want to create a new reference off of an existing reference, referring to the same object, so that I can close the new reference without closing the original reference. The original reference needs to outlive this VI. Is there a way to do this?
(3,173 Views)
I just solved it like so, but I'd like if there was a more generic way to get a new reference, because this doesn't really scale for different types.
(3,152 Views)
Can you call ParentClass once before enter the loop, avoid pass Parser into the loop?
George Zou
(3,142 Views)
Yes that's a good option, and then i would only call the loop if it has a parent. Also, I did change it to use recursion instead of a loop, but the question still remains. I guess I have a couple different options. Also, to simplify slightly I found there is an OpenClass method which keeps me from needing to use OpenLibrary with a cast to a class:
(3,133 Views)
Accepted by topic author GregFreeman
I'd avoid the problem altogether...
(3,053 Views)
Nice use of pipelining. Definitely didn't think of this.
(2,973 Views)
