Read value from multistring input
I have this multistring:
How can I read the line with "channel[16]" to return just the number 3?
I have attached my attempt.  Not sure why its not working.  Any help will be sincerely appreciated!
(1,894 Views)
I would really make code to read the whole message and just pick that one line.  It's not that much more difficult (might even be easier), and there's a high probability that you'll need to read the other stuff as well.  Always code with scalablity in mind.
Bill
CLD
(Mid-Level minion.)
(1,872 Views)
Accepted by topic author hiNI
Here's an alternative using the Spreadsheet String To Array and then searching the array for the desired string.
(1,856 Views)
