Create OPC I/O server and front panel data socket problem
Hi all!
I installed the NI OPC server. When I try to create a new server I/O in a LabVIEW project I don't see the "OPC client" possibility.
Is something software missing?
Other question: I tryed to connect to OPC server using front panel data socket but my problem is same. When I click the numeric control and I go to the "data operation" menu there is no possibility to make data socket connection.
I don't know what is the problem.
I attached two pictures about my problem.
(3,906 Views)
Accepted by vajasgeri1
Dear vajasgeri1,
do you have LabVIEW DSC module installed? Without it you will not have the OPC client funtionality.
And to configure DataSocket binding you need to go to the Data Binding tab in the Properties of a control.
BR,
(3,859 Views)
Thank you for your anwser! I have installed the DSC module and it resolved my problem!
I also found the DataSocket configuration.
Best regards!
(3,819 Views)
