Create Simultaneous Dial and Numeric control?
I have a dial that outputs a number to the program when turned (and indicate the number in the indicator text box)  but it is hard to be precise with just the dial, so i want to create the option to write in the text box that displays the numbre present on the dial. is there a fast way to do this?
(5,313 Views)
Did you try to input the value in the "text" box (actually a numeric control) ?
Obviously not ! Otherwise you wouldn't have asked this question !
Chilly Charly    (aka CC)
(5,300 Views)
Hey Supermario,
Your best bet would to select the dial on the front panel of the VI and right click -> visible items -> digital display. That will provide you with a numeric box next to the dial which will allow you to manually input numbers.
Regards
Andrew George @ NI UK
(5,299 Views)
Accepted by superomario
Smiley Wink
Right click on the dial, goto visible items, click on digital display.
That should do it
(5,298 Views)
Digital Display! Thanks a lot! Smiley Happy
(5,292 Views)
So what was the "indicator text box" in your first post ? I'm puzzled !
(5,276 Views)
