Create a Driver with Labview
Hello, for a job that i will start the next month I have to create a driver for some Non-NI instruments using labview.
Could you provide me some files where I can read how to do it, what kind of commands I need to use to comunicate with the instruments and so on?
THank you in advace.
(3,982 Views)
(3,972 Views)
What instrument?  What communication bus are you using?  Does it have a programmer's guide?  Did you look in the IDNet to see if there is already a driver written?
You are talking very generically.  If you have more specifics, we can give better information.
(3,932 Views)
Hi actually i don't know with what kind of instrument i'll have to comunicate. the question is generical because i want to start to study and read as much as i can so that i can have a background knowledge on those subjects  🙂
(3,921 Views)
start here https://www.ni.com/en/support/downloads/instrument-drivers/types-of-instrument-drivers.html
There are a lot of good related articles.
(3,913 Views)
Assuming a common problem and solution, it's serial communication, in which case you bundle command (e.g. Send "P" to a unit to get it to print its value) as vi's and read back and interpret the result. This result will be the output.
Qestit Systems
Certified-LabVIEW-Developer
(3,882 Views)
