Create and open type def in one step
I am always making typedefs. They're super helpful and make my code much easier to modify. However! I must right click and select Make Typedef, Then right click again to open the type def and save it. This is annoying. Under what circumstance would I create and then not also open and save a typedef? My preferred behavior would be that when I create a typedef, the control is immediately opened for modification and saving. In fact, the prompt to save might pop up automatically as well.
Maybe someone has create a quickdrop shortcut for this....
_____________
Creator of the BundleMagic plugin for LabVIEW!
(1,480 Views)
Maybe not exactly what you ask for but might save you some time if check "Open the control editor with double click".
George Zou
(1,466 Views)
A close second to that annoyance is that it always creates the typedef at the top level of the project instead of in the library of its "host" so you always have to drag it into the correct library and change its icon.
Bill
CLD
(Mid-Level minion.)
(1,458 Views)
Here is an idea I posted to correct that:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Type-Def-made-inside-a-library-VI-should-be-part-of-t...
Raphaël.
(1,449 Views)
I gave it a vote.
Bill
CLD
(Mid-Level minion.)
(1,442 Views)
I rarely make type defs anymore since I switched to OO.
Just an occasional enum, but never clusters...
When I do create a type def enum, I simply mark the enum as type def, and wait for LV to ask me so save it when I close the VI. So for me this is a rather convenient workflow, although it's not clear what is saved first (esp. in the even rarer case where you marked 2 controls as new type def).
It's sooner look into LabVIEW Shortcut Menu Plug-Ins - NI Community.
This can actually replace LabVIEW's menu (if you want it to). You might get it to do exactly what you want.
It's a bit tricky to get going with shortcut menu plug-ins, but what you request doesn't sound too difficult.
(1,381 Views)
