Modbus master does not read holding register
Hello everyone.
I created a simple VI with Modbus master and slave that write and read holding registers. Unfortunately I cannot read the values ​​written (in the same vi) with the slave with the master.
Any suggestions?
Thank you
A
(936 Views)
Can you save it for 2020 ?
(910 Views)
Here ver. 2020.
Thank you
(857 Views)
What is the error message?
Make sure the slave starts before the master. Wire the error out terminal of the slave to the error in terminal of the master.
(846 Views)
The values ​​read by the master are always 0.
Thank you
A
(836 Views)
