Create bar plot diagram like excel template
Hi
Is it possible to create a diagram like the one I attached? It was built in Excel and I'd like to have it in LabView.
Thanks for any help
Yves
Message 1 of 9
(3,947 Views)
Hi Yves,
yes, that's possible.
Spoiler
You need to play with all those plot properties…
Message 2 of 9
(3,944 Views)
Well I already tried but couldn't set two bar plots next to each other.
Any suggestions?
Message 3 of 9
(3,928 Views)
Hi Yves,
what have you tried so far?
I can set bar plots next to each other, like shown here.
Message 4 of 9
(3,922 Views)
Hi Gerd
I'd like to have two separate bar plots for each time step. Blue is a channel and red another one.
Yves
Message 5 of 9
(3,913 Views)
Hi Yves,
that's ok. In my example picture (lower right corner) I had more than two bar plots next to each other…
What's your problem? "I'd like to…" is just a "wish", but no "problem"!
What have you tried before?
Message 6 of 9
(3,909 Views)
Thank you for help.
Ok, like is wish. Then I have a problem 🙂
I have attached a the test vi that I have build to try to solve the problem.
Somehow I also haven't found a way to display the values in another way than the listbox.
Yves
Message 7 of 9
(3,904 Views)
Accepted by topic author Yves
Hi Yves,
you might refine this to your needs:
Message 8 of 9
(3,895 Views)
Thank you Gerd. I'll modify the goal a litle bit and with this solution it'll be fine.
Yves
Message 9 of 9
(3,883 Views)
