Create list of combination
Hi abhinandan,
please change your subVI "Partial product" like this:
No need for local variabels - or even more worse "value" property nodes!
You need to learn about using AUTOINDEXING!
- Why do you use "Wait (ms)" instead of "Get Time"?
- Remove local variables, especially those used to update the indicator. They all take processing time…
Message 11 of 13
(933 Views)
I have made that change.
the code looks more professional now
thank you
Smiley Happy
But this does not seem to solve the problem of execution speed.
Did you get better results with the suggested changes ?
the main vi still takes more than a minute for a larger input array
 Smiley Sad
I am pretty sure that the sub vi was not the problem
Smiley Sad
Message 12 of 13
(925 Views)
I'm pretty sure the subVI was part of the problem: using "value" property nodes is way more slow than working directly with data using shift registers or autoindexing…
You need to cleanup your mainVI too: remove locals, use indexing, ...
Message 13 of 13
(917 Views)
