Creating ENUM dynamically from string Array
I was wondering if it was possible to create an ENUM dynamically? For example, I would like to read in values from a string array and use each element to add a new item in the ENUM control. If this isn't possible, how do I configure a case structure to read in the values from a string array like an ENUM would normally be able to? It would help tremendously if I didn't have to manually enter the string name for each particular case. Thanks so much.
Message 1 of 9
(24,689 Views)
Search the forum, you'll find this question has been asked many times before.
Short answer is: no, it's not possible to populate an enum at runtime. Also, if you don't know what values the enum can have at runtime what cases should the case structure have?
So if you know the values at design time, you can use an enum. If not, use a ring.
Hope this helps,
Daniel
Message 2 of 9
(24,679 Views)
Accepted by Newbie217
Ditto Dan's comments.
If you are asking because you just want to save a lot of work at edit time you could wrie all of your strings to a ring and then afterwards right-click and choose replace >>> enum and the object will change to an enum with all of the ring's strings.
Remember to include default case since you are dealing with strings.
I hope that helps,
Ben
Message 3 of 9
(24,654 Views)
However if you have a lot of strings and want to create an enum, you can do this one initial time.
See the LabVIEW code repository.
Ton
My LabVIEW Ideas
Message 4 of 9
(24,641 Views)
Using the Ring approach and converting it to an ENUM after works great! Thank you! Basically, what I was trying to accomplish was a way of obtaining all the variable labels to setup a case structure. This works great!
Message 5 of 9
(24,608 Views)
great idea for saving time!
Message 6 of 9
(21,835 Views)
Presumably you are the same person on LAVA that claimed to have code to take an array and make it into an strict type def enum.  A) your code doesn't work because it cannot be encorporated into projects (password protected, etc), B) If you are going to provide solutions on a public help forum why do a password protect on the code.
Message 7 of 9
(18,421 Views)
Hi muzza,
who is "you" when you answer in a very old thread?
Message 8 of 9
(18,386 Views)
The words in that post sound very familiar, but I couldn't find the thread. I wonder if this is a spambot about to happen...
Message 9 of 9
(18,369 Views)
