Creating a 3D Array
Hi, I am trying to create a 744x2 array from two 2D arrays created from two spreadsheet files, loaded as text files. I can output separate 2D, 744x1, arrays for both, however, I am unable to merge the the two together to create two columns. Only one column is shown.
Any help would be appreciated.
(6,614 Views)
So you are creating a 3D array, but you actually want a 2-D array?
Use index Array to get the 0th column on your two 2-D arrays.  Then use Build Array to concatenate the resulting two 1-D arrays into a 2-D array.
(6,601 Views)
Thanks for the reply. That is correct, the resultant array should be 2D, not 3D. I believe I've followed your instructions however, the resultant array is now 1D.
(6,592 Views)
Accepted by topic author LabVIEWnovice99
Hi novice,
When you need columns after "merging" (aka building an array rowwise) you need to transpose the 2D array:
Why do you read your spreadsheet files as strings when you convert them to numeric data anyway? Just read them using the "DBL" version of ReadDelimitedSpreadsheetFile!
What's the point of indexing single elements from your arrays in the last message?
It seems you really should take all those "Training resources" as offered in the header of the LabVIEW board!
(6,589 Views)
That's brilliant, thank you.
(6,583 Views)
Because you used Index Array to grab a single element, not a single column!
Put a zero in the column index input and nothing wired to the row index input.  Then you get the entire 0th column.
(6,561 Views)
First of all, your files only have one column, so you should get the 1D output instead. (If you transpose=T you get the first column instead of row). If you don't really need the strings, you can even get the DBL directly. Now just built it onto a 2D array and transpose if desired.
(6,512 Views)
