This widget could not be displayed.
Creating a Sub-VI with no reference..
I have a question on a Sub-VI. I am driving from a memory array certain indicator property nodes at different offsets. For the reason of clutter on my top level, when driving many of these, can these go into a Sub-VI? I have tried to do this but it gives me many top level references stacked on each other. Not sure what its doing.
On the top level i wanted these indicators updated on an event change and would be the same in the Sub-VI.
i put in pic of the partial block diagram..
thanks
(3,524 Views)
Attached picture isn't visible (broken link).
Edited: also I would like to add, attaching your code (or may be a prototype code around your idea) will help us to understand the problem statement better.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,519 Views)
here is the picture..
(3,512 Views)
You could get references to all of the controls on the main VI's front panel and operate on them:
You'll probably have to add logic to identify the particular controls you want to manipulate.  You can do that with the Label property.
Jim
(3,472 Views)
