Creating a TDMS file that is compatible with DIAdem properties
Hi all
What I am trying to do is create a TDMS file that has the ‘Unit’ TDMS property already populated. The issue is that my code creates a custom property rather than setting the "default" unit feild:
Below is a code snippet of what I am currently doing:
If anyone can spot what i am doing wrong or know how to set the 'default' proprties i would be very greatful.
Cheers
Dave B
(3,657 Views)
Accepted by topic author D.Barr
Hi D.,
try the attributes as are used for waveforms!
(3,640 Views)
Cheers GerdW waveform did indeed help.
Also if you right link on the property in DIAdem and use the help you can find the property name. For example setting the a waveform x axis unit property is called wf_xunit_string.
Thanks for the helps
Dave B
(3,614 Views)
