02-15-2016 02:21 AM
Hi all
What I am trying to do is create a TDMS file that has the ‘Unit’ TDMS property already populated. The issue is that my code creates a custom property rather than setting the "default" unit feild:
Below is a code snippet of what I am currently doing:
If anyone can spot what i am doing wrong or know how to set the 'default' proprties i would be very greatful.
Cheers
Dave B
Solved! Go to Solution.
02-15-2016
02:44 AM
- last edited on
11-07-2024
01:19 PM
by
Content Cleaner
02-15-2016 03:18 AM
Cheers GerdW waveform did indeed help.
Also if you right link on the property in DIAdem and use the help you can find the property name. For example setting the a waveform x axis unit property is called wf_xunit_string.
Thanks for the helps
Dave B
