Creating a graph with data
Good day. I would like to know how to create a graph, using data from an array. I have attached my Vi and the data that is collected at the end of the 20 cycles, as viewed on the front panel, I am trying to create a graph that will show a hysterisis loop, using that data. The test is supposed to go 0-200V, then 200V-0V. It is for a free displacement test using an eddy current sensor.
Also, I am trying to figure out how to create an indicator that gives a graphical representation of what voltage level the test is at, an animated sort of a thing. I couldn't find anything in my training material. Thank you
Message 1 of 16
(6,131 Views)
To just show an array of values, you can add a Graph indicator to your Front Panel and then wire the array to the graph.
Which values in your VI, exactly, do you want to graph?
As far as "an indicator that gives a graphical representation of what voltage level the test is at", you probably just want to wire your voltage value directly to a Chart indicator.
Here is an article about types of graphs in LabVIEW.
Cheers
Message 2 of 16
(6,112 Views)
Which values in your VI, exactly, do you want to graph? The two columns under the "Displacement" heading.
Message 3 of 16
(6,101 Views)
Did you follow the link I put above? That should help you get familiar with gaphs and charts. This is one of the great things about LabVIEW, you can really easily add a user interface component and wire your data to the indicator. You can create a graph or a chart to display your "Actual" values in plotted form.
Cheers
Message 4 of 16
(6,093 Views)
Did you follow the link I put above? Yes sir, I did. The are easy enough when the data is a direct match. However, I had to use Fract/Exp String to Number's for the "Up values" and "Down Values", then build an array using scaleable numbers, then feed that to the waveform graph but it gives me an incompatability message, when I connect the appended array to the waveform graph.
Message 5 of 16
(6,078 Views)
If you would, please create a subVI of the code you're having trouble with that just does the array operations and outputs the information to a graph. I can't run your VI because I don't have MyDAQ drivers installed, so it would be helpful to have just a subsection of the code to work with. You could also select and create a Snippet of the code you mentioned here for us to see.
Cheers
Message 6 of 16
(6,072 Views)
You could also select and create a Snippet of the code you mentioned here for us to see. I have never used Snippet before. For some reason, when I select the part of my Vi to make a snippet it puts indicators and controls all over the place and broken lines. It isn't representing well what I have selected.
Message 7 of 16
(6,049 Views)
Another problem I am having is making it so that it is displacement over voltage, not over time. I haven't found a way to change it yet. So the graph should make a near oval shape, with sharp ends, if that makes any sense at all.
Message 8 of 16
(6,033 Views)
Go ahead and make a snippet and a subVI anyways and attach it here. I can try to sort through any broken wires or extra controls. It's easier to at least see what you've tried so far, so I can better tell what you're try to do.
You can use an XY Graph indicator to graph the voltage vs displacement. Bundle the X axis (voltage?) array along with the  Y axis (displacement?) array together and write them to an XY Graph.
Cheers
Message 9 of 16
(6,021 Views)
You can use an XY Graph indicator to graph the voltage vs displacement. Bundle the X axis (voltage?) array along with the  Y axis (displacement?) array together and write them to an XY Graph. Okay, I will give it a try.
Message 10 of 16
(5,972 Views)
