Creating a graph with data
@James.M wrote:
Go ahead and make a snippet and a subVI anyways and attach it here. I can try to sort through any broken wires or extra controls. It's easier to at least see what you've tried so far, so I can better tell what you're try to do.
I am having no luck at all. When I try to drag and drop that snippet to my reply, it takes away my NI page and shows only snippet, as a URL. I can't get it to paste into this reply. This probably should be easy but I can't get it.
Message 11 of 16
(1,615 Views)
You should be able to either insert the snippet by selecting Choose File at the bottom of the reply, or your can click the little Insert Picture button.
Cheers
Message 12 of 16
(1,604 Views)
I think it worked this time.
Message 13 of 16
(1,591 Views)
Yes, the snippet worked. Do you have a snippet of the code you have tried with the graph? I would like to see the code where you did this:
@ceilingwalker wrote:
I had to use Fract/Exp String to Number's for the "Up values" and "Down Values", then build an array using scaleable numbers, then feed that to the waveform graph but it gives me an incompatability message
Cheers
Message 14 of 16
(1,586 Views)
It didn't work, but it should have been on the snippet. I don't understand, I thought the snippet would be like a screenshot but it isn't.
Message 15 of 16
(1,563 Views)
It is like a screenshot, but it also contains some of the code in the file properties so I can see the code...
Cheers
Message 16 of 16
(1,559 Views)
