Creating a nice interface
how can i create a nice interface with proper alignment and spacing in labview ..like this
(6,533 Views)
Time and effort... and also, don't be colorblind like I am.  😉
Bill
CLD
(Mid-Level minion.)
(6,506 Views)
Could you explain more about the problems you're running into in creating an interface like that?
It looks like most of those controls are system. You just place them down where you want them to be on the front panel. Use the toolbar to neatly line them up. Toolbar.png
If you are asking about how to make it resizeable, that is trickier. Usually what I do is plan my UI carefully so there is a part of it that doesn't need to expand (like buttons), and then part of it that can easily expand as much as needed (like a graph) and then put them in separate panes and configure it so just the easily expanded part grows when the window is resized.
(6,500 Views)
It is possible. Here is something I knocked up in 10 minutes. I used a free UI toolkit from DMC (https://www.dmcinfo.com/services/test-and-measurement-automation/labview-programming/labview-ui-suit...).
There are plenty of toolkits free and paid on VI package manager. Flat Controls by JDP Science and the one from JKI are free and quite useful.
P.S: I don't have any association with any of the companies above.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(6,483 Views)
the simple way is to add you components,
use the align functions as HopeH showed,
and enable the gridsnapping (i don't know what it is called)
en-/disable with CTRL+#
more involved is using splitters and tabs,
have a look at the containers palette,
and search for the terms in help/forum/google.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(6,455 Views)
What can I say?  The first time I tried to put together an interface with custom colors, someone physically cringed.  It was then that I realized that I shouldn't be designing interfaces without help.  😉
Bill
CLD
(Mid-Level minion.)
(6,422 Views)
As a general guide, I always try to make simple and minimalistic GUI. Often, I use the System palette for the Front Panel controls/objects. This gives you a "usual" familiar looking interface similar to other applications in Windows. As an extra to the built-in System palette, I also install the following add-on: https://www.ni.com/en/support/downloads/tools-network/download.operating-system-ui-controls-toolkit....
Edit:
other thing I often overlooked in the past, that you should NOT show ALL input (control) options to the user at once. The GUI looks terrible if you have too many elements. There are several tricks how you can minimise the number of controls/indicators in your GUI. TABs can be OK, but might introduce big problems if overused. More pro solution using subPanels, but they require more programming. You can also consider using pop-up dialog windows, to give the user access to controls which are not frequently needed to be interacted, or indicators to see by the user.
Other useful thing is using custom Runtime Shortcut menus (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3TOCAY&l=en-US ), either for the Top level VI's front panel, or for individual controls/indicators.
One example I often use: I have two indicators, one shows the actual Flow Rate of a flow controller. The other indicator shows the actual Set Point. I create a custom shortcut menu for the Setpoint indicator, so the user can change the setpoint via right mouse click, bringing up a menu, then depending on the choice, opening a dialog window...
(6,387 Views)
