Web service Access Error 500: Internal Server Error
Hi, Everyone.
I try to create my web service like this topic (https://forums.ni.com/t5/LabVIEW-Web-Development/Getting-Started-Series-See-an-Image-of-the-Front-Pa...). but It's end up with Access Error 500: Internal Server Error and I don't have any idea to fix it.
I try it with Add.VI in my project.
Can someone help me fix this?
Thanks!
(5,432 Views)
Hi Vindecua,
In order to be able to help you, I need to know more about what you are trying to do.
-What version of LabVIEW are you using?
-What operating system are you using?
-Can you post a screen shot of what you are seeing?
I would also like you to try one of the web service examples built into LabVIEW, to see whether you see the same error. I would recommend trying Address Book.lvproj. In order to get to this project follow these steps:
  • Open LabVIEW
  • Click on help and then go to find examples.
  • On the left of the page you will see browse and search tabs. Click on the search tab and then enter in webservice.
  • Double click on webservice and it will pull up examples. Then double click on Address Book example to open
  • Run the example
Let me know if this works or if you get the same error
(5,360 Views)
Hi, sherlockholm.
Now I'm already fixed this problem.
It's just I'm put the files in the wrong place in project.
Thanks for try to help!
Chonnawee
(5,351 Views)
