Creating a virtual COM port
Hello
I have an instrument that streams data each second and an application that reads that data and processes it.
The instrument recently got updated with some new commands, which the application can't properly process, but i can't fix the application at this time.
So my idea was to read instrument data with another "dummy" application and write data with Labview to a virtual COM port that the other application could then access/read. Is this possible with Labview or is it too much work?
Message 1 of 14
(17,727 Views)
Hi AeroSoul,
so you want a "virtual virtual COM port" and not one of those "real virtual COM ports" (aka USB-to-RS232 devices)? 😄
I don't know if there is a software/driver that simulates COM port (like there is for CAN ports with the NI-CAN driver). But you may use several of those "virtual COM port" USB devices to solve your problem!?
Message 2 of 14
(17,723 Views)
Accepted by AeroSoul
In the past I used the null-modem emulator com0com (on sourceforge.net).
From the LabVIEW standpoint, com0com should be transparent, just another COM port in the system.
Paolo
Message 3 of 14
(17,716 Views)
The instrument connects to computer with USB cable and application connects to COM port that is created/opened (shows up in device manager) when instrument is plugged in.
What i want to do is create a "man in the middle" application that would read that COM port and create a virtual one, from which then the original application would read.
Usually this wouldn't be needed, but as said we want to try some new commands and the OG application doesn't handle them well (formatting issues). So the "MitM" application would basically record the actual output of the instruments and sanitize it, so the OG application could handle it.
Message 4 of 14
(17,686 Views)
It's still all a bit vague. So this other application is not a LabVIEW application but something existing? And you want to write a LabVIEW application that reads from the USB virtual COM port, mangles the data somehow, transfers it to a virtual virtual COM port that your application then can connect to?
If this describes the thing you face then you would have to look into com0com as mentioned already. This software lets you create two virtual virtual COM ports that are connected together through the com0com driver. Your LabVIEW opens the USB virtual COM port AND one of the com0com virtual ports and translates the data between the two as needed. Your app connects to the other com0com virtual port instead of the USB virtual port and sees whatever your LabVIEW writes into the other side of the com0com link and anything that it sends will then be read by LabVIEW.
It is a little complicated as your LabVIEW app needs to handle incoming data from both sides properly in parallel, so your loop needs to monitor both ports in parallel for incoming data and process it to send it to through the other port out. This is one point where the Bytes at Serial Port would have some merits, not to read how many bytes you must read but to see if there is ANY data to be processed. If that value is not 0 you need to read data according to whatever the communication protocol would demand, most likely until a termination character is seen, process that data to massage it into the other format and then send it out through the other port. You would have to do that for both ports in parallel (in the same loop).
Alternatively you could do a separate loop for each port which monitors the incoming data and transfers any such data to the other loop through a queue after having it properly transformed.
Rolf Kalbermatter  My Blog
Message 5 of 14
(17,672 Views)
Yeah you want a simulated loopback COM port. Try this:
https://www.hhdsoftware.com/virtual-serial-ports
It's got a free demo you can use. It makes two COM ports that loop to each other and will be totally transparent to your computer. Your program than then read the actual device on a real COM port then shoot the sanitized data out the mirrored port. com0com may work too but I haven't tried that one myself.
Message 6 of 14
(17,648 Views)
com0com does work but it is open source and with the normal warranty that comes with these free things: If it works it works and if it doesn't it's up to you to make it work! 😀
Most commercial tools providing this feature are more or less based on the com0com code or its predecessor but cleaned up, with neat installers and scripts that make everything work more smoothly on different Windows versions, including newer ones.
If you care to tinker or rather pay is everyone's own decision. 😁
Message 7 of 14
(17,643 Views)
Alright, the solution is already accepted and it's com0com, works fine tho two way communication was a bit of a pain to implement.
For those wondering the instrument in question is NDIR CO2 analyzer which sends a string of data. The new command implemented is that negative CO2 values are also allowed (until now only positive were allowed and anything negative got written as 0). With this new command comes a new error tho, specifically if the value of CO2 is negative, it sends another string after the first, which is an error string warning you that the value is in fact negative.
This second string breaks the OG application, as it was not designed to handle it (it is a labview application AND i have the source code... but i'm not allowed to change it). So the "MitM" basically receives the data and removes any error strings and then send measurements to the OG application.
Message 8 of 14
(17,563 Views)
Yes I was imagining that it might be a bit of a challenge to write a piece of software that crossbars two serial ports. Although your device seems to be a talker only device? That would make it fairly simple as you don't have to worry about one direction of the data stream. If you need to support bidirectional data transfer the challenge is to handle both incoming data streams in a way that neither of them blocks the handling of the other when waiting for data.
One wonders about the reasoning of such management decisions:
No it is a critical application and you can NOT make any changes to it before 500 security officers have read the proposal, gave their mustard to it and eventually signed it off, but installing an additional device driver (which is always a significant change to a computer) plus creating a new application that massages the strings and fakes things is no concern whatsoever. 😁
You have to love such hypocrisy.
Message 9 of 14
(17,545 Views)
Luckily the talkback is minimum, only several commands are sent, so my solution was to just stop reading a port while Bytes at port was not empty. Only delays the stream by one second and in the end it still gets updated because termchar was enabled.
Actually in this case i kinda agree with not changing OG source code, as the test was made to see if negative values (or more precisely calculations with negative values) are supported by the OG application.
I will admit that i also wanted to change the source code but creating a port forwarding was actually easier in the end (despite using third party program)
Message 10 of 14
(17,534 Views)
