Creating an Array that holds a specific range of values.
Is there an easy way to create a 1D array that simply has the numbers 0 through 1023 held in it?
(3,773 Views)
Yes, simply use a FOR loop with n=1024 and autoindex the loop counter at the right loop boundary. (See attached image).
(3,773 Views)
That's exactly what I'm looking for. But does 6.1 have an autoindex array?
(3,773 Views)
Actually.... let me be a bit more specific on what I am trying to do. I am trying to take History data from a waveform chart and correlate the sample number to the time using a conversion factor of 625uS per sample. Then I want to redisplay this data on a separate chart with the time scale as opposed to the sample scale.
(3,773 Views)
In this case you don't need to generate any array at all. Just use a waveform graph (not chart or x-y) and do one of the following:
(1) If this value remains fixed during the program execution, just ring-click on the graph and select x-scale..formatting and enter you x0 and dx. dx would be 635e-6. On the right, change the formatting ot e.g. engineering notation as needed.
(2) If you need programmatic control over this, create a property node for the graph (right-click..create..property node), set it the "change all to read" and select property "Xscale..offset and multiplier...multiplier". Now wire your the increment/point (625e-6) to the multiplier terminal.
(3,773 Views)
