Is there a way to set up flags
I would like to set a flag inside of a case structure, which will be used in deciding if the case is true, ex.
flag IsSet=false
if (SomeThing is true && IsSet is false)
enter case
set IsSet to true
exit
(3,163 Views)
Just use a boolean for your flag, then you can use boolean logic operations. Everything you need is available in the boolean palette.
(3,163 Views)
I have done that, but in order to do this you will end up with a boolean control on the front panel. I desire a method in which the front panel is unaltered. I appreciate your help, though.
(3,163 Views)
You can use boolean diagram constants.
(3,163 Views)
