Creating an executable file
Hello. I am using Windows 7 Professional. I am trying to create an executable. I searched here and am also watching youtube videos plus my online NI training, and following directions. The problem is, all of the examples I could find are using earlier versions of windows. I attached my project as well as a screenshot of what is happening. I have it done however, when I double-click the executable it doesn't open the Vi, it opens the file used to create the executable. I don't know if the difference is because of OS but I followed behind the videos as much as possible, with a few question marks because what I have isn't exactly what the training videos show. I also have LV 2014 and it doesn't match with the training videos either but it seems as though there isn't a major difference between the two. If I haven't provided enough information let me know. The password to the Vi is "2015". Thank you
Message 1 of 8
(5,779 Views)
Accepted by ceilingwalker
Within the executable build specification ("Piezo rig"), go to the "Source Files" tab and add you main VI ("Piezoelectric displacement test exe.vi") to the Startup VIs section.
You shouldn't have any issues based on operating system or LabVIEW version. Make sure that you install the matching Runtime engine along with the executable if you're deploying to a different computer.
Cheers
Message 2 of 8
(5,774 Views)
I am not sure what this is nor how to do it. :manembarrassed:
Message 3 of 8
(5,750 Views)
I did this, that's why I am not sure why it opens the executible properties window.
Message 4 of 8
(5,747 Views)
Why don't you click on the Help button?
You should create an installer after you build the exe. LabVIEW requires a runtime engine to execute when you don't have the development environment and you can include it when you create the installer.
What is the point of password protecting your VI? The block diagram is removed during the build.
Message 5 of 8
(5,744 Views)
Like Dennis said, build an Installer as well as the executable. You can google how to do this pretty easily.
The project file that you attached didn't have that option set up properly. This might be because you idnd't include any of the VIs though, just the project file.
Cheers
Message 6 of 8
(5,734 Views)
What is the point of password protecting your VI? The block diagram is removed during the build. Yes Sir, I found this out after my executable worked. I will disable the password protection. When it opens the LV Vi, it takes half the screen, not full screen however, I haven't searched for a solution to that yet but am working on it now. Thank you for your support.
Message 7 of 8
(5,720 Views)
Mess around with your VI properties for Window Appearance. You can make it maximize when opened.
Cheers
Message 8 of 8
(5,710 Views)
