Creating and adding to JSON file
This may be a simple problem and I'm just not understanding some of the previous forum posts, but I'm trying to:
  1. Create a JSON file
  2. Add objects to that file
Following the solution in this post  Solved: Using LabVIEW to compose JSON strings incrementally - NI Community I was able to build a JSON string. I was then trying to add to one of the JSON arrays by following the solution in this post Solved: Add object into JSON file - NI Community.
My code looks like this:
and I'm getting this output:
I want the JSON to read as follows:
When I try to run the code I get the following error:
Is there an obvious error to the path or the variable types that I am overlooking? Do I need to change input to the JSON string that I'm trying to add to a variant?
Thanks for the help.
(4,543 Views)
Accepted by Phteven_722
(4,499 Views)
