Creating array and writing to a txt file
Hi, I would like to ask you.
I have an 1D array and I would like to create a txt file with two columns. First is an index of the element and the second is the value of this element.
How would it be possible?
(1,415 Views)
Accepted by JohnJohn2012
Here is a quick and dirty version.
(1,409 Views)
Thank you for the answer. Could I kindly ask you, what is the name the function with pencil o the image, because I unfortunately have labview 2019, so I can`t open this file.
(1,403 Views)
Write Delimited Spreadsheet.vi
Attached the LabVIEW 2019 version.
(1,396 Views)
EDIT: that crossed. This solution is a bit more flexible though. For instance, the 1D array could be a string (you didn't specify).
Also note that the %.; should be used in any solution, or you'll get problems in when your application or it's data moves regions.
(1,393 Views)
