Creating axis names by programming
Hello again. I tried to define the axis names with different units by programming instead of doing in the graph properties. As in my vi, I wired each axis name corresponding to the unit input to the graph property node, but it didn't come out correctly. I can't even see all graphs in the waveform chart which I defined each graph name already. How can I deal with it?
Message 1 of 18
(4,725 Views)
more subvi
Message 2 of 18
(4,718 Views)
In order to have charts with different physical quantities (e.g. pressure & flow), the charts must be stacked.
You can get around this by giving them a transparent background color, resizing the stacked charts and positioning them on top of each other.
Message 3 of 18
(4,716 Views)
What about my plotting code? Is it correct? I think it's already right but the chart doesn't show all lines corresponding to the data inputs.
Message 4 of 18
(4,700 Views)
maybe your data is appending, try right clic in the graph and deselect that option.
Regards
Message 5 of 18
(4,683 Views)
Where is that option? I didn't see it :(.  Is there anything wrong with my code in this case?
Message 6 of 18
(4,666 Views)
sorry, I mistook. I wanted to say Transpose Array.
Regards
Message 7 of 18
(4,655 Views)
I tried to take the transpose array out but it's still not working. Anyone has any ideas?
Message 8 of 18
(4,637 Views)
Do you have Context Help turned on? When you move your mouse over the chart on the block diagram, that will tell you the correct way to format data for it. Your use of the Build Array inside the loop is just wrong as well as wiring the 2D array to the chart (transposed or not). A multiplot where you are getting a single point at a time requires a bundle function - just like the help window shows.
Message 9 of 18
(4,629 Views)
Attached a vi, but I think work better with xy graph because you use No. in the x axis
Message 10 of 18
(4,615 Views)
