How do I put each element of an array of 30 elements to each slot in a cluster?
There are 30 columns in a table in an access db file.
Currently, I have an array of 30 floating point numbers.
I want to know how to put each of array elements in each slot in a cluster of 30 slots with DB Tools Insert Data VI.
(2,362 Views)
You can use the array to cluster primitive
Rodéric L
Certified LabVIEW Architect
(2,348 Views)
