Creating buttons that have numeric value to run a motor.
You could add another state to the state machine called "Pause" which will wait 1 second then move to the "Up" or "Down" state and then return to standby when complete
Message 21 of 22
(284 Views)
How would I keep it stalling at -1 or 1 so it can continue to go up/down before it returns 0? Also 0 won't return to orignal position for my appilication. For example if I go up it would be -1 then to go down would be 1. Inputting a 0 won't do anything for my application. That's why I orginally needed a button that holds both -1 and 1 and add a timed function so that I could keep it up/down before reversing. My motor controlled through VISA. I need the program perform this way: Click button labeled as "Cycle Once" > Labview will send -1 which is up. It could return to 0 or be kept as -1 while it run. I need a time control where i would manually input how long to keep it running up > afterwards when the time as elapsed it would send 1 which is down. That is basically it. I was able to modify your vi by switching the "is equal" returning -1,0,1 when i click up. But, it would keep looping through those numbers. Thanks for your responce. I'll keep trying to figure out how to edit your VI until then.
Message 22 of 22
(272 Views)
