Crio stops when IE is closed and Webserver is not reachable anymore
Hello
I actually have a small problem that is making me sick 😉
It is generating some DIO/AO output signals that are controlling a piece of Hardware,
and like 2secs after powering the cRIO 9024 it starts to send those signals. This is what I wanted
to do and it works quite fine. Additionally there are some values that are displayed in a VI.
I installed the webserver, built my RT-Startup file, deployed everything and it runs perfect, BUT:
As soon I open the frontpanel in the Internet Explorer I can play around like hours and it works
nice, but when ich close the Internet Explorer Window everything stops AO`s, DIO`s and also the webserver
is stopped.
If i try to reconnect it says the vi isn`t available in the memory anymore
I want it to keep running after closing the webbrowser, to reconnect to it again later if I want to, without going to
the system making a power-down reset. How can I fix this issue?
Martin
(2,464 Views)
Additionally I have to say that the cRIO and the Webserver itself keeps running, it just seems that the vi is closed.
It says the vi is not in the memory of the host anymore?!
(2,448 Views)
