Custom Waveform Generation
Hi, I am trying to tweak my sine wave generation to have sharper peaks at the wave maxima and minima. I wanted to add two waveforms together to do this, although I'm open to better ideas.
I've attached what I'm trying to do. I got close to the shape I'm looking for , but how can I get the waveform to repeat across the whole interval without manually inputting all the values to 1 in the simulate signal vi?
Also is there a way that I can make the second waveform being added adjustable for different frequency's?
For example, if I decide to use a 100hz signal and add these sharper peaks and valleys, but then want to change to a 200 hz signal. I would like the secondary waveform to match up with the frequency interval, and have constructive interference in the correct locations.
I hope that makes some sense.
Thank you for your help,
Arthur J.
Message 1 of 9
(4,682 Views)
Maybe something like this?
Message 2 of 9
(4,645 Views)
Thank you very much for helping me out,
could you possibly bring it into LabView 2009 for me though, I don't have LV10 available to me.
Thanks again,
Arthur J.
Message 3 of 9
(4,630 Views)
My apologies, here you are
Message 4 of 9
(4,611 Views)
maybe this is a dumb question, but wouldn't that be the same as doubling the amplitude of just one wave?
Message 5 of 9
(4,598 Views)
Yes and No, This absolutely will double the amplitude of your signal, but one is a sine wave and the other is a triangle wave.  The triangle wave will give each amplitude a sharper peak.
Message 6 of 9
(4,584 Views)
Thanks again, and sorry for being away for a while.
I tried to implement it in my code but I recieved an error regarding matching sampling rates between channels.
For example say I have 2 channels being written. Channel 1 is a sine waveform with sampling info of:
Fs = 10K
#s = 10K
I tried to make Channel 2 the combined waveform with each part (triangle, sine) having Fs of 10K and #s = 5K, but I got an error that I need all the waveforms to match
How can I maintain information so that I can have the daq device output one channel of the pure sine wave and one channel of the sine+triangle waveform?
Thanks for your help,
Arthur J.
Message 7 of 9
(4,524 Views)
I'm not too clear on what you are trying to do, please post your code and screen shots so that I can better understand the issue. Thanks,
Message 8 of 9
(4,493 Views)
I took a piece of the whole vi, and attached it to show what I mean.
I think the issue is in the sampling information given to the waveforms being generated, but I'm just not sure on how to configure them correctly.
Thanks for any help,
Arthur J.
Message 9 of 9
(4,465 Views)
