Crop video while Capturing
Hello Sirs,
For my project I am undertaking non-contact PPG acquistion. I am trying to capture my webcam but with the whole image I am getting a lot of noise in the signal. I have found using some example code provided by my supervisor in MATLAB that my webcam is capable of recording at 30fps.
I have integrated a video capture for processing in other programs. The VI currently records in a text file.
How would you suggest I crop the video frames before they are captured or processed, I need this for two reasons, 1. the whole image generates noise and 2. reduce the output file footprint.
 I have attached the VI for reference. To make it run a text file file path needs to be designated for the VI to run and a session for your WEBCAM.
Regards Sean
P.S Vision Required.
(5,195 Views)
Hey,
i would have a look at this example:
https://decibel.ni.com/content/docs/DOC-11222
Hopefully that will help you
James
(5,157 Views)
I'll give it a go.
(5,150 Views)
Accepted by topic author seancassidy
If you open your camera in MAX, there may be properties for the width and height. You can create a property node on your camera session and use these names as the "active attribute" and then set the "value" with a string or numeric.
(5,135 Views)
That is the best solution. What I have reverted to doing was to capture video, then crop it outside labview, then process it by each frame
(5,123 Views)
 In this example, we will create a program in Labview to capture images from a USB camera to your application for further processing using the NI Vision module.
You can perform image acquisition only drivers from VAS , but for any treatment or handling or VDM VBAI you need , plus VAS . You can download the evaluation software from the following links :
Módulo NI Vision Development https://lumen.ni.com/nicif/us/evalvisiondevmodule/content.xhtml NI Vision Builder para Inspección Automatizada (AI) https://lumen.ni.com/nicif/us/machinevisionbrochure/content.xhtml NI Vision Acquisition Software http://joule.ni.com/nidu/cds/view/p/id/3818/lang/en
https://decibel.ni.com/content/docs/DOC-30531
(4,940 Views)
