Cropping Video Images
I was wondering how to crop video images as they run. Is there a vi module that can be used to do this? Examples I have seen online used a now nonexistant IMAQ extract.
(4,359 Views)
Accepted by Cenoc
What do you mean a "nonexistant" IMAQ extract?
Are you sure your vision module is well installed?
It is possible to "crop" images, I think there are examples in LabVIEW. Help > Find examples... > search tab
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,356 Views)
Ah, I apparently didnt have it installed. The issue is when I run it as part of the video, it crashes. Ive attached the current assembly. Before I put the extract in, it works.
(4,351 Views)
I am trying to reduce the image sizes so that the saved avi is smaller.
(4,346 Views)
Could you please make a snippet from your project and post the resulting PNG here in the forum?
Here is a little Snippet - How-To:
Use VI Snippet to Store and Share Reusable Code Sections
(4,306 Views)
