Cross-Covariance
I need to calculate the cross-covariance of two vectors. How do I do this if I don't have MathScript (and hence can't use 'xcov')?
Thanks!
(3,136 Views)
Accepted by ap8888
There is Cross-Correlation VI within LabVIEW that should work for you
Andy Chang
(3,121 Views)
This VI can be found in Signal Processing->Signal Operation
Applications Engineer
(3,103 Views)
