Cross-platform alternative to LabVIEW
Apart from LabVIEW the only cross platform language that I've seen anyone ever reach for was Xamarin when a fast POC had to be done by some developers on IOS and Andriod at the same time with the possibility of needing a desktop app to go alongside on IOS and windows later. (If I'm remembering the project correctly) - but even for highly experienced C# developers that was a steep learning / re-learning curve in the timeframe of the short project.
If your code is too closely coupled at the moment I'd work on reducing the coupling in the short term whilst you look to what the best solution language-wise is for migration in the long term, it may be that packaging quite a bit of the LV code as DLLs will allow you to move to another language faster than re-writing everything from scratch.
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 31 of 34
(1,186 Views)
NET MAUI is the successor of Xamarin
(.NET MAUI Finally Replaces Xamarin in Visual Studio 2022 17.3 Preview 1 -- Visual Studio Magazine).
Not sure if it's easier...
Message 32 of 34
(1,152 Views)
Now the acronym fun begins when you are dealing with .NET MAUI to control LeCroy MAUI:
https://www.teledynelecroy.com/maui/
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 33 of 34
(1,133 Views)
Well I've learned something new today.
My daughter has previously taught me that Maui is a Disney character who has a hook and now I find it's programming language.
Mind you, I also used to think that Xamarin sounded like some sort of small monkey from the South America though - so it's always good to learn.
Message 34 of 34
(1,094 Views)
