The setup is this :
1. Card is PCMCIA 6024E.
2. Software is LV 7.1 and all reads are with DAQMx functions.
3. 6 analog channels configured in differential mode ( AIN_0 to AIN_5)
4. Connected to the card via BNC2110 connector.
If I connect only one channel to a signal, it is reflected in all the other 5 channels at different levels.
I do know that I can solve this problem by two means :
A. Ground the unused channels to AIGND.
B. Use alternate channels with one grounded channel in between two active channels.
In my case since I need all 6 channels at times, so option B does'nt exist.
Question is, can something be done in the software without resorting to option A.
I have attached the snap shot of my problem. The straightline plot is the channel that has a signal on it and the other "followers" are free channels. At 15:49:43 I made the active channel zero and you can see all of them dropping to zero. Then I started another channel and all of them pick up !
Kindly help solve this.
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
