Ctrl+. doesn't work with win2000
"Operate->Stop" shortcut (Ctrl+.) doesn't work with win2000.
LabVIEW6i
(4,083 Views)
It works here on my machine with Windows 2000. Perhaps you have deselected "Show Abort Button" under "VI Properties>>Window Appearance>>Customize..." If this option is not checked then Ctrl + . will not work. If you do not want to show the Abort button but still want Ctrl + . to work then uncheck the "Show Toolbar When Running" option.
Brian
(4,083 Views)
Thanks for the answer Brian but "Show Abort Button" is selected (the same file work with Win98). In win2000 with "Ctrl+." It generates a beep.
Roberto
(4,083 Views)
Thats interesting, maybe there is some other process running that is capturing that key stroke? I tried a bunch of different things and couldn't get "Ctrl+." to not work on my Windows2000 machine.
(4,083 Views)
I have resolved the problem.
"Ctrl + ." work on my Windows2000 machine only with the point of the numeric pad ("," del).
Thank you very much.
Roberto
(4,083 Views)
That's very strange - could you please post a copy of the VI you are having trouble with so we can have a look at it?
Copyright © 2004-2026 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(4,083 Views)
The problem is with all VI, also with those "empty" ones.
(4,083 Views)
